smoke-71
#1 Posted : Tuesday, March 3, 2015 3:56:21 AM(UTC)
smoke-71
i have a dryer that dont heat i have checked all the componaints and they are all good even by a meter is there anything else it could be that i am missing
fairbank56
#2 Posted : Tuesday, March 3, 2015 8:10:51 AM(UTC)
fairbank56
Groups: Expert
Did you check for 240vac at the dryer cord connection block?
Eric
smoke-71
#3 Posted : Tuesday, March 3, 2015 8:20:17 AM(UTC)
smoke-71
Yes I have votage on the board where the plug goes it just won't heat up there is a circuit in the motor I have 240 on both sides of the circuit but it seems to not making a closed curcuit
smoke-71
#4 Posted : Tuesday, March 3, 2015 8:22:59 AM(UTC)
smoke-71
The motor runs and everything else just don't heat at all
fairbank56
#5 Posted : Tuesday, March 3, 2015 10:23:14 AM(UTC)
fairbank56
Groups: Expert
With timer at OFF, disconnect the red wire from the hi limit thermostat. Make sure it isn't touching anything. Turn timer on to timed heat cycle. What is the voltage to ground at either heat element terminal?
Roper Dryer RES7745PQ0 (Dryer Repair)
by ARC575 4/19/2020 3:58:45 PM(UTC)
Roper Dryer: won't start, need help! (Dryer Repair)
by FerociousBeast 1/4/2017 5:45:40 PM(UTC)
Whirlpool Roper dryer timer (Dryer Repair)
by kparker1028 1/2/2017 9:15:02 AM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 1/26/2016 6:08:16 AM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Whirpool Roper Dryer heat but doesn't spin (Dryer Repair)
by Kjeffrey02 1/2/2016 12:25:54 PM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Auto sense dry roper dryer pops fuse dial does not advance (Dryer Repair)
by Chuckpie85 9/11/2015 4:59:42 PM(UTC)
Roper Dryer stops working, then heater runs in all cycles including no heat. (Dryer Repair)
by econobiker 1/7/2015 8:50:40 AM(UTC)
roper dryer not heating (Dryer Repair)
by JONCNC1976 1/6/2015 7:05:49 AM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
Roper dryer only dries in timed mode (Dryer Repair)
by dmpsqrd 8/22/2014 11:24:59 AM(UTC)
