Rank:: Member
i have a dryer that dont heat i have checked all the componaints and they are all good even by a meter is there anything else it could be that i am missing
Groups: Expert
Did you check for 240vac at the dryer cord connection block?
Eric
Rank:: Member
Yes I have votage on the board where the plug goes it just won't heat up there is a circuit in the motor I have 240 on both sides of the circuit but it seems to not making a closed curcuit
Rank:: Member
The motor runs and everything else just don't heat at all
Groups: Expert
With timer at OFF, disconnect the red wire from the hi limit thermostat. Make sure it isn't touching anything. Turn timer on to timed heat cycle. What is the voltage to ground at either heat element terminal?
