smoke-71
#1 Posted : 10 years ago
smoke-71
i have a dryer that dont heat i have checked all the componaints and they are all good even by a meter is there anything else it could be that i am missing
fairbank56
#2 Posted : 10 years ago
fairbank56
Groups: Expert
Did you check for 240vac at the dryer cord connection block?
Eric
smoke-71
#3 Posted : 10 years ago
smoke-71
Yes I have votage on the board where the plug goes it just won't heat up there is a circuit in the motor I have 240 on both sides of the circuit but it seems to not making a closed curcuit
smoke-71
#4 Posted : 10 years ago
smoke-71
The motor runs and everything else just don't heat at all
fairbank56
#5 Posted : 10 years ago
fairbank56
Groups: Expert
With timer at OFF, disconnect the red wire from the hi limit thermostat. Make sure it isn't touching anything. Turn timer on to timed heat cycle. What is the voltage to ground at either heat element terminal?
Roper Dryer RES7745PQ0 (Dryer Repair)
by ARC575 5 years ago
Roper Dryer: won't start, need help! (Dryer Repair)
by FerociousBeast 8 years ago
Whirlpool Roper dryer timer (Dryer Repair)
by kparker1028 8 years ago
Roper dryer not starting. (Dryer Repair)
by tekgeek 9 years ago
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 9 years ago
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 9 years ago
Roper dryer heating problems (Dryer Repair)
by laurencp72 9 years ago
Whirpool Roper Dryer heat but doesn't spin (Dryer Repair)
by Kjeffrey02 9 years ago
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 9 years ago
Roper Dryer not drying (Dryer Repair)
by fhorta 9 years ago
Auto sense dry roper dryer pops fuse dial does not advance (Dryer Repair)
by Chuckpie85 10 years ago
Roper Dryer stops working, then heater runs in all cycles including no heat. (Dryer Repair)
by econobiker 10 years ago
roper dryer not heating (Dryer Repair)
by JONCNC1976 10 years ago
roper dryer no heat (Dryer Repair)
by chuck vaughn 10 years ago
Roper dryer only dries in timed mode (Dryer Repair)
by dmpsqrd 11 years ago
