patkat3
#1 Posted : Friday, June 13, 2014 8:04:56 AM(UTC)
patkat3
I have a Kitchen Aid washing machine that fills with water, but won't agitate or spin. I checked the motor coupling first and that seems to be OK. The motor doesn't smell hot or look burned. Am I looking at a bad transmission? Also, should I be able to turn the agitator by hand in either direction ?
fairbank56
#2 Posted : Friday, June 13, 2014 8:27:11 AM(UTC)
fairbank56
Groups: Expert
Does the motor run? Does washer drain? You should be able to rotate upper agitator in clockwise direction only. Lower agitator depends on if washer last stopped in agitate mode or spin mode. If motor runs and washer drains ok but no agitation or spin, most likely a bad coupler. Remove motor to check for sure. Rotating transmission input shaft CCW with half of coupler should cause agitation, CW for spin. Make sure shaft is rotating and not just coupler worn and slipping on shaft.
Eric
patkat3
#3 Posted : Friday, June 13, 2014 9:00:08 AM(UTC)
patkat3
Washer does not drain. Coupler looks OK. How can I check the motor to see if it's OK ?
fairbank56
#4 Posted : Friday, June 13, 2014 11:41:55 AM(UTC)
fairbank56
Groups: Expert
Does the motor make any noise? If it just hums, may be something jamming the pump. Pull pump from motor (leave hoses connected) and see if washer will now agitate or spin.
Eric
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 5/13/2023 11:34:56 AM(UTC)
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 1/11/2019 8:43:20 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 8/24/2015 9:59:30 AM(UTC)
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 3/21/2015 2:16:27 PM(UTC)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Profile Washer Won't Agitate or Spin (Washer Repair)
by WisconsinMatt 8/19/2014 11:34:42 AM(UTC)
Kenmore 90 series washer won't agitate or spin (Washer Repair)
by JayDigger 1/31/2014 9:30:29 AM(UTC)
Washer won't agitate or spin (Washer Repair)
by Jojam3000 12/17/2013 2:06:10 PM(UTC)
Frigidaire Washer Won't Agitate Or Spin (Washer Repair)
by paulem 10/7/2013 5:50:21 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
by Stephenluck 6/12/2013 12:34:39 AM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
Washer won't agitate or spin, can turn motor by hand (Washer Repair)
by englaisfitz 11/14/2012 5:49:24 AM(UTC)
washer won't agitate or spin, goes through cycles, fills and drainss (Washer Repair)
by kb4bill 6/4/2012 12:58:12 PM(UTC)
