paulem
#1 Posted : Monday, October 7, 2013 5:50:21 AM(UTC)
paulem
FRIGIDAIRE MODEL #gltf2070ds0 WON'T SPIN OR AGITATE.
THE DOOR IS LOCKING. THE MACHINE READS ALL CYCLES BUT WILL NOT AGITATE OR SPIN. IT WILL DRAIN WATER.
THERE IS NO ERROR CODE SHOWING.
I HAVE REPLACED THE CONTROL PANEL, THE SPEED CONTROL BOARD IN THE BOTTOM OF THE MACHINE AND THE MOTOR.
NO WIRING SEEMS TO BE BAD.
IS IT POSSIBLE THAT THE DOOR LOCK SWITCH IS BAD ALTHOUGH THE DOOR IS LOCKING?
sidfink43
#2 Posted : Tuesday, October 8, 2013 3:41:29 PM(UTC)
sidfink43
Yes, that sounds like your problem. If the machine does not think the door lock is engaged even when it is it will not operate. And you may have a wiring issue from the door lock to the control board even if you cannot see any problem.
