3 Pages123>
Jojam3000
#1 Posted : Tuesday, December 17, 2013 2:06:10 PM(UTC)
Jojam3000
Ok so I'm new to the washing machine forum world. Didn't even know such a forum existed lol. I have read some similar issues like mine on this forum but none of the machines look quite like mine. I think mine is a bit older. I've been looking for inline fuses on my wires and can't seem to find them. My motor isn't turning on therefore my machine is not spinning or agitating. Please help:confused:
fairbank56
#2 Posted : Tuesday, December 17, 2013 2:38:47 PM(UTC)
fairbank56
Groups: Expert
No fuses on this model. No noise at all from the motor? Timer advances on it's own through the cycle? Check your lid switch. Bad lid switch = no motor function.
Eric
Jojam3000
#3 Posted : Tuesday, December 17, 2013 2:44:16 PM(UTC)
Jojam3000
I appreciate the quick reply. And yes I was chatting with one of the pros and they told me there was a relay.. I located the relay but there are so many pins on it I didn't know on which one to check for continuity. And how do I test this lid switch motor?
fairbank56
#4 Posted : Tuesday, December 17, 2013 3:12:10 PM(UTC)
fairbank56
Groups: Expert
Well, you didn't answer either of my questions. Is there any noise at all (humming) from the motor when it should be running? Does the timer advance on it's own normally? The relay is for selecting the proper start/run winding depending on speed selection. To test the lid switch, you need to unplug the lid switch connector and check continuity on the lid switch while holding the lid magnet against it.
Eric
Jojam3000
#5 Posted : Tuesday, December 17, 2013 3:18:30 PM(UTC)
Jojam3000
Sorry..yes the dials click normally through all cycles and no humming from engine at all I will check the switch
Jojam3000
#6 Posted : Tuesday, December 17, 2013 3:23:04 PM(UTC)
Jojam3000
Eric
I have no continuity at the switch
fairbank56
#7 Posted : Tuesday, December 17, 2013 3:30:52 PM(UTC)
fairbank56
Groups: Expert
You will need to replace the switch. You can jump out the switch to temporarily operate the machine. You would need a piece of 16 gauge wire that fits tightly into the harness connector as this wiring carries full motor current during normal operation.
GE WH12X10531 Lid Switch Asm - AppliancePartsPros.com
Eric
Jojam3000
#8 Posted : Tuesday, December 17, 2013 3:35:41 PM(UTC)
Jojam3000
Thank u so much!!! Ok so where do I jump the cable to? From what pin to what pin?
Jojam3000
#9 Posted : Tuesday, December 17, 2013 3:51:43 PM(UTC)
Jojam3000
Eric
So basically I can just bypass it till the switch arrives?
fairbank56
#10 Posted : Tuesday, December 17, 2013 3:58:14 PM(UTC)
fairbank56
Groups: Expert
Yes, it's only a 2-pin connector. Jump the two pins together. That's the wiring harness receptacle, not the connector on the end of the lid switch :) Believe me, people have done that before.
You can just cut the plug off the lid switch wires leaving a couple inches so you can strip the wires, twist them together good, and tape them or wirenut them and plug that jumped connector into the harness receptacle.
This is only for temporary use, as it's a safety issue. Make sure no youngsters can get near the washer while it's running this way til you get that switch replaced.
Eric
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 5/13/2023 11:34:56 AM(UTC)
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 1/11/2019 8:43:20 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 8/24/2015 9:59:30 AM(UTC)
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 3/21/2015 2:16:27 PM(UTC)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Profile Washer Won't Agitate or Spin (Washer Repair)
by WisconsinMatt 8/19/2014 11:34:42 AM(UTC)
by patkat3 6/13/2014 8:04:56 AM(UTC)
Kenmore 90 series washer won't agitate or spin (Washer Repair)
by JayDigger 1/31/2014 9:30:29 AM(UTC)
Frigidaire Washer Won't Agitate Or Spin (Washer Repair)
by paulem 10/7/2013 5:50:21 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
by Stephenluck 6/12/2013 12:34:39 AM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
Washer won't agitate or spin, can turn motor by hand (Washer Repair)
by englaisfitz 11/14/2012 5:49:24 AM(UTC)
washer won't agitate or spin, goes through cycles, fills and drainss (Washer Repair)
by kb4bill 6/4/2012 12:58:12 PM(UTC)
3 Pages123>
