patkat3
#1 Posted : 11 years ago
patkat3
I have a Kitchen Aid washing machine that fills with water, but won't agitate or spin. I checked the motor coupling first and that seems to be OK. The motor doesn't smell hot or look burned. Am I looking at a bad transmission? Also, should I be able to turn the agitator by hand in either direction ?
fairbank56
#2 Posted : 11 years ago
fairbank56
Groups: Expert
Does the motor run? Does washer drain? You should be able to rotate upper agitator in clockwise direction only. Lower agitator depends on if washer last stopped in agitate mode or spin mode. If motor runs and washer drains ok but no agitation or spin, most likely a bad coupler. Remove motor to check for sure. Rotating transmission input shaft CCW with half of coupler should cause agitation, CW for spin. Make sure shaft is rotating and not just coupler worn and slipping on shaft.
Eric
patkat3
#3 Posted : 11 years ago
patkat3
Washer does not drain. Coupler looks OK. How can I check the motor to see if it's OK ?
fairbank56
#4 Posted : 11 years ago
fairbank56
Groups: Expert
Does the motor make any noise? If it just hums, may be something jamming the pump. Pull pump from motor (leave hoses connected) and see if washer will now agitate or spin.
Eric
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 2 years ago
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 6 years ago
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 8 years ago
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 10 years ago
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 10 years ago
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 10 years ago
GE Profile Washer Won't Agitate or Spin (Washer Repair)
by WisconsinMatt 11 years ago
Kenmore 90 series washer won't agitate or spin (Washer Repair)
by JayDigger 11 years ago
Washer won't agitate or spin (Washer Repair)
by Jojam3000 11 years ago
Frigidaire Washer Won't Agitate Or Spin (Washer Repair)
by paulem 11 years ago
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 12 years ago
by Stephenluck 12 years ago
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 12 years ago
Washer won't agitate or spin, can turn motor by hand (Washer Repair)
by englaisfitz 12 years ago
washer won't agitate or spin, goes through cycles, fills and drainss (Washer Repair)
by kb4bill 13 years ago
