DDEBRUS
#1 Posted : Sunday, January 19, 2014 11:20:20 AM(UTC)
DDEBRUS
i have replaced the cycling thermostats and continue to have issues with it taking too long to dry clothes. Would it help to replace the thermo fuse?
fairbank56
#2 Posted : Sunday, January 19, 2014 12:36:05 PM(UTC)
fairbank56
Groups: Expert
Double check the model number, doesn't come up. If dryer is heating, thermal fuse is ok.
Eric
#3 Posted : Monday, January 20, 2014 2:12:19 AM(UTC)
The most common cause of long dry times is a partially plugged vent system.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
GAS DRYER TAKES TOO LONG TO DRY, OE DOESN'T DRY AT ALL. (Dryer Repair)
by MAYTAG MANIA 7/20/2022 2:05:06 PM(UTC)
Dryer heats up but takes too long to dry (Dryer Repair)
by bear0729 11/13/2018 6:35:10 AM(UTC)
Samsung takes too long to dry (Dryer Repair)
by Scottiedg 4/23/2017 3:59:22 PM(UTC)
dryer takes too long to dry (Dryer Repair)
by cdhenson68 1/1/2015 11:54:59 AM(UTC)
Takes too long to dry (Dryer Repair)
by myersv 4/1/2014 2:35:28 PM(UTC)
Maytag gas dryer LSG7904AAE takes too long to dry (Dryer Repair)
by mr1022 1/2/2012 11:27:21 AM(UTC)
whirlpool leb6400lw0 Takes too long to dry (Dryer Repair)
by itsmatt 6/12/2011 11:26:33 AM(UTC)
by mark stevenson 5/3/2011 8:38:32 PM(UTC)
Whirlpool Dryer (gas) takes too long to dry on Energy Efficient mode (Dryer Repair)
by Ranae 12/12/2009 8:16:06 AM(UTC)
Roper dryer takes too long to dry (Dryer Repair)
by bluefitness 8/15/2009 6:16:45 PM(UTC)
by Sean O 3/3/2008 6:33:49 AM(UTC)
Takes too long to dry:Duet (Dryer Repair)
by Scottpiggs 8/8/2007 2:37:09 PM(UTC)
