myersv
#1 Posted : Tuesday, April 1, 2014 2:35:28 PM(UTC)
myersv
I have a GE dryer that worked just fine up until a couple weeks ago. Now it seems to take longer and longer for it to dry. I don't have the model number handy but I can get it later. It is electric. What is the most likely thing to have gone wrong with it? Thanks.
mr_mjsjr
#2 Posted : Tuesday, April 1, 2014 3:02:19 PM(UTC)
mr_mjsjr
the most common thing, if the dryer is actually getting hot is for the vent to be blocked or crushed. go outside with the unit running and feel the vent, it should be good and strong; if not or unsure, go inside and remove the vent from the rear of the dryer. the airflow outside should come close to matching the airflow directly out of the machine.
myersv
#3 Posted : Tuesday, April 1, 2014 6:01:41 PM(UTC)
myersv
Thanks. I haven't been able to clear it yet but I looked at the vent. There is barely any opening for any air to pass.
GAS DRYER TAKES TOO LONG TO DRY, OE DOESN'T DRY AT ALL. (Dryer Repair)
by MAYTAG MANIA 7/20/2022 2:05:06 PM(UTC)
Dryer heats up but takes too long to dry (Dryer Repair)
by bear0729 11/13/2018 6:35:10 AM(UTC)
Samsung takes too long to dry (Dryer Repair)
by Scottiedg 4/23/2017 3:59:22 PM(UTC)
dryer takes too long to dry (Dryer Repair)
by cdhenson68 1/1/2015 11:54:59 AM(UTC)
Takes too long to dry (Dryer Repair)
by DDEBRUS 1/19/2014 11:20:20 AM(UTC)
Maytag gas dryer LSG7904AAE takes too long to dry (Dryer Repair)
by mr1022 1/2/2012 11:27:21 AM(UTC)
whirlpool leb6400lw0 Takes too long to dry (Dryer Repair)
by itsmatt 6/12/2011 11:26:33 AM(UTC)
by mark stevenson 5/3/2011 8:38:32 PM(UTC)
Whirlpool Dryer (gas) takes too long to dry on Energy Efficient mode (Dryer Repair)
by Ranae 12/12/2009 8:16:06 AM(UTC)
Roper dryer takes too long to dry (Dryer Repair)
by bluefitness 8/15/2009 6:16:45 PM(UTC)
by Sean O 3/3/2008 6:33:49 AM(UTC)
Takes too long to dry:Duet (Dryer Repair)
by Scottpiggs 8/8/2007 2:37:09 PM(UTC)
