DDEBRUS
#1 Posted : 11 years ago
DDEBRUS
i have replaced the cycling thermostats and continue to have issues with it taking too long to dry clothes. Would it help to replace the thermo fuse?
fairbank56
#2 Posted : 11 years ago
fairbank56
Groups: Expert
Double check the model number, doesn't come up. If dryer is heating, thermal fuse is ok.
Eric
#3 Posted : 11 years ago
The most common cause of long dry times is a partially plugged vent system.
Unplug the unit and disconnect it from the vent system.
Now try a run.
If it now dries OK odds are the vent system needs checking/cleaning.
Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house.
Take a pair of pantyhose.
Put one leg into the other and then attach this to the dryer's vent.
Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns.
GAS DRYER TAKES TOO LONG TO DRY, OE DOESN'T DRY AT ALL. (Dryer Repair)
by MAYTAG MANIA 3 years ago
Dryer heats up but takes too long to dry (Dryer Repair)
by bear0729 6 years ago
Samsung takes too long to dry (Dryer Repair)
by Scottiedg 8 years ago
dryer takes too long to dry (Dryer Repair)
by cdhenson68 10 years ago
Takes too long to dry (Dryer Repair)
by myersv 11 years ago
Maytag gas dryer LSG7904AAE takes too long to dry (Dryer Repair)
by mr1022 13 years ago
whirlpool leb6400lw0 Takes too long to dry (Dryer Repair)
by itsmatt 14 years ago
by mark stevenson 14 years ago
Whirlpool Dryer (gas) takes too long to dry on Energy Efficient mode (Dryer Repair)
by Ranae 15 years ago
Roper dryer takes too long to dry (Dryer Repair)
by bluefitness 16 years ago
by Sean O 17 years ago
Takes too long to dry:Duet (Dryer Repair)
by Scottpiggs 18 years ago
