i have replaced the cycling thermostats and continue to have issues with it taking too long to dry clothes. Would it help to replace the thermo fuse?
Groups: Expert
Double check the model number, doesn't come up. If dryer is heating, thermal fuse is ok.
Eric
The most common cause of long dry times is a partially plugged vent system.
Unplug the unit and disconnect it from the vent system. Now try a run. If it now dries OK odds are the vent system needs checking/cleaning. Be sure to check that the louvers on the outside of the house open correctly.
If you do not want any lint in the house. Take a pair of pantyhose. Put one leg into the other and then attach this to the dryer's vent. Leave enough room so the pantyhose can balloon out like a windsock.
Both the above will let you check the temperature and the air flow.
Note: The above is not recommended for gas dryers due to carbon monoxide concerns. |
THIS FORUM IS DEAD!!!!!!! |
