redbug
#1 Posted : Wednesday, October 2, 2013 11:06:09 AM(UTC)
redbug
I purchased a defrost thermostat from repair ************ and testing it upon arrival (placing it in ice and testing for continuity with a multimeter) and it showed no needle movement. Is it possible that it arrived dead or am I doing something wrong?
#2 Posted : Thursday, October 3, 2013 2:06:00 AM(UTC)
Yes it could be bad right out of the box.
I cannot say if you are doing something wrong.
Perhaps you did not hold it on the ice long enough.
Did you short the meter leads together before measuring just to be sure your meter was OK.
Looking at the part on AppliancePartsPros it should open at 47 and then re-close at 25 degrees F.
Defrost Thermostat Stuck Closed? (Refrigerator & Freezer Repair)
by tim.widmann 6/3/2021 10:32:14 AM(UTC)
Want to give away a GE defrost thermostat (Refrigerator & Freezer Repair)
Belarus Jorabi 6/27/2018 7:12:27 AM(UTC)
Defrost thermostat open/closed (Refrigerator & Freezer Repair)
by Jorabi 3/11/2018 5:25:55 PM(UTC)
refrigerator defrost thermostat (Refrigerator & Freezer Repair)
by joline 3/4/2017 2:15:53 PM(UTC)
Universal Defrost Thermostat (Refrigerator & Freezer Repair)
by rlogan 10/12/2016 1:06:39 PM(UTC)
Defrost thermostat rating (Refrigerator & Freezer Repair)
by RichNJ 9/3/2016 12:18:17 AM(UTC)
Replacing a 3 wire defrost thermostat (Refrigerator & Freezer Repair)
by arvetus 8/19/2016 6:53:56 PM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Replacing Defrost thermostat on (GE) Kenmore (Refrigerator & Freezer Repair)
by AUricle 7/14/2016 9:05:45 PM(UTC)
defrost thermostat not on Whirlpool diagram (Refrigerator & Freezer Repair)
by chrisyews 7/18/2015 6:22:00 AM(UTC)
Ice Build-up On Defrost Thermostat (Refrigerator & Freezer Repair)
by dantucson 7/31/2014 5:39:50 PM(UTC)
Defrost Thermostat DOA? (Refrigerator & Freezer Repair)
by spam 7/9/2014 3:27:06 PM(UTC)
How to test a defrost thermostat that has 4 wires (Refrigerator & Freezer Repair)
by appliance13 6/4/2014 3:20:27 PM(UTC)
Difference between defrost thermostats? (Refrigerator & Freezer Repair)
by Sockit 4/29/2014 8:10:13 AM(UTC)
Ice buildup on Defrost Thermostat (Refrigerator & Freezer Repair)
by russell@txwrights.com 1/20/2014 5:49:09 PM(UTC)
