venmsss
#1 Posted : Tuesday, October 1, 2013 8:15:58 AM(UTC)
venmsss
while washer fills,machine starts to agitate...should only agitate after water level has been reached
fairbank56
#2 Posted : Tuesday, October 1, 2013 9:38:57 AM(UTC)
fairbank56
Groups: Expert
Open control panel and disconnect pressure hose from back of temperature switch. Blow into hose to make sure it's clear, reconnect hose. If it's loose, cut minimal amount of hose from end and reconnect. If it still does the same thing, replace the switch.
Whirlpool W10248240 Temperature Switch - AppliancePartsPros.com
Eric
venmsss
#3 Posted : Saturday, October 5, 2013 7:06:04 PM(UTC)
venmsss
thank you eric...wasn`t sure if problem was in timer or pressure switch...i`ll get back with you with the result...thanks again for your help Eric...scott.
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
Maytag Centennial Washer MVWC415EW0 Agitation issue (Washer Repair)
by Guest 5/27/2021 9:58:45 PM(UTC)
maytag centennial washer (Washer Repair)
by arodriguez01 2/6/2018 8:29:06 AM(UTC)
maytag centennial washer low fill (Washer Repair)
by redjada 9/3/2017 9:01:47 AM(UTC)
Maytag Centennial Washer doesn't Agitate (Washer Repair)
by hosehead78 4/16/2017 5:46:30 PM(UTC)
Maytag Centennial Washer Stops Mid-Cycle (Washer Repair)
by washer2017 3/16/2017 5:58:01 AM(UTC)
Maytag centennial washer drum sits too low (Washer Repair)
by jansmeall 12/8/2016 11:59:20 AM(UTC)
maytag centennial washer wont goo into spin cycle (Washer Repair)
by shennondw 8/9/2016 6:20:41 PM(UTC)
Maytag Centennial Washer (Washer Repair)
by fivermillions 2/21/2016 5:23:23 AM(UTC)
Maytag Centennial washer stops after filling (Washer Repair)
by dfrancey 5/5/2015 7:41:28 AM(UTC)
Maytag Centennial washer will not start (Washer Repair)
by TurnpikeJ09 3/8/2015 7:44:44 PM(UTC)
by maytagQuestion 3/2/2015 1:11:52 PM(UTC)
by Scotty1231 10/5/2014 7:45:25 AM(UTC)
Maytag Centennial Washer Transmission??? (Washer Repair)
by Fixit-teer 4/13/2014 6:58:06 PM(UTC)
by ShadeTree231 3/23/2014 5:02:51 PM(UTC)
