washer2017
#1 Posted : Thursday, March 16, 2017 5:58:01 AM(UTC)
washer2017
My Maytag Centennial washer MVWC300VW1 is stopping mid-cycle and won't drain, it makes a buzzing noise for a few seconds when it stops agitating and then stops. If I try to manually advance the dial nothing happens. I can manually drain it by lowering the hose and I've inspected for blockage and there's none. I have also replaced the pump and it's still doing the same thing. I've checked the lid switch for continuity and that appears fine. Any thoughts on what's causing this?
jimctec
#2 Posted : Thursday, March 16, 2017 8:42:58 AM(UTC)
jimctec
Possible bad timer not putting power for motor rotation in that direction while still running in agitate direction.
romanticgorilla
#3 Posted : Thursday, March 16, 2017 3:25:07 PM(UTC)
romanticgorilla
Not trying to jack your thread but I have the same exact problem as you except I have Maytag Centennial MVMC7ESWW0. I would love to hear more possible causes for this. Sometimes the washer will work fine and other times is will stop mid-cycle right before it drains and spins. jimctec, Would a bad timer cause the brief buzzing noise that washer2017 mentioned?
romanticgorilla
POS Maytag Owner
#4 Posted : Sunday, March 19, 2017 9:07:56 AM(UTC)
POS Maytag Owner
Same problem here. Maytag Model # MVWC200XW2, and today, the tub fell about 2" down, as if the support or springs went bad
