AppliancePartsPros.com
Appliance Repair Help
Washer Repair
maytag centennial washer wont goo into spin cycle
I have a maytag centennial commercial technology top load washer that works fine up to spin cycle, it wont drain and go into spin cycle, the top door remains locked and the red light just blinks, does anyone have the same or similar, I read where someone replaced the actuator and it solved their problem, does this sound like a fit:confused: I have used this washer very heavily doing 40 loads per week for up to 5 years and never have had an issue until now, I did notice however where the top door locks on the door side it looks like burn marks does this mean anything does this help????
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
It very much could be your problem as the shift actuator transfers the transmission in and out of agitation mode. It also is the tub rotation speed sensor. Here is your part Whirlpool WPW10006355 Shift Actuator - AppliancePartsPros.com And don't forget our Buy and Try policy. See the ad at the top of your part page.....
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Here is a Youtube video on how to go about fixing a Maytag Centennial washing machine:
Washer Repair
