dryer will not light igniter glows then shuts off on regular cycles have replaced thermal disc any ideas darryl:confused:
Ohm out the ignitor it should be 0-70 Ohms..........if not replace.........More then likely it's a coil issue if it's not releasing the gas replace the coils their about 20 bucks
