which line on the condenser does the defrost thermostat go on? also where is the defrost timer located on this model? replaced the defrost thermostat whit one from you guys and want to make sure I put it on the right line if it makes a difference.
I cannot say other than it should clip to one of the coils at the top.
Check them for scratches that were cased by the original thermostat. |
THIS FORUM IS DEAD!!!!!!! |
