Having problems with ice dispenser. Whenever flap is pushed to dispense ice, nothing happens. Tried replacing ice dispenser motor but no fix. I am now thinking that this is a switch problem. Any ideas??
Does the water dispenser work?
Water dispenser works. After some investigating found microswitch under dispenser cover was loose from bracket. (bracket was broken) Ordered new bracket and placed microswitch in correct position. Works fine now.
I'm glad you were able to fix it.
