MichelleM74
#1 Posted : 12 years ago
MichelleM74
My kenmore washing machine makes a humming noise. You can slam the lid and it will start working. Sometimes it will so all the way to the rinse cycle before it stops and starts humming again. If I catch it will it's making the noise I can slam the lid and it will start working again if I don't catch it I can let it set for a few minutes then go and pull the knob out again and it will either hum or be working. I'm wondering if it could be the hidden lid switch.
sidfink43
#2 Posted : 12 years ago
sidfink43
Normally the lid switch will be bad and just shut things off, but this does sound like a lid switch problem. Change it out and see if that fixes things. If not, the timing or the wiring to the motor or even the motor itself could be the problem.
Kenmore Washing Machine Model 417.29042992 (Washer Repair)
by jimylegg1 5 years ago
Sears Kenmore Washing Machine 80 Series (Washer Repair)
by purecountry1127 9 years ago
Kenmore washing machine not spinning without help (Washer Repair)
by narcsisuss 10 years ago
Kenmore Washing Machine (Washer Repair)
by DStephens075@aol.com 11 years ago
Kenmore washing machine, agitates while filling. (Washer Repair)
by Scott Eddy 11 years ago
kenmore washing machine only fills (Washer Repair)
by stevieray2 12 years ago
kenmore washing machine top load (Washer Repair)
by bigfig 13 years ago
Series 90 Kenmore washing machine NO COLD WATER (Washer Repair)
by Char H 13 years ago
kenmore washing machine wont start (Washer Repair)
by buddy93 13 years ago
Kenmore washing Machine (Washer Repair)
by sstrueblue 13 years ago
Kenmore Washing Machine Timer Shaft (Washer Repair)
by GLion 14 years ago
My Kenmore Washing Machine (Washer Repair)
by ignefeus 14 years ago
kenmore washing machine (Washer Repair)
by ron walburn 14 years ago
kenmore washing machine series 70 (Washer Repair)
by raineywillow 14 years ago
Kenmore Washing machine (Washer Repair)
by bjhamrick 15 years ago
