MichelleM74
#1 Posted : Saturday, January 12, 2013 11:51:42 AM(UTC)
MichelleM74
My kenmore washing machine makes a humming noise. You can slam the lid and it will start working. Sometimes it will so all the way to the rinse cycle before it stops and starts humming again. If I catch it will it's making the noise I can slam the lid and it will start working again if I don't catch it I can let it set for a few minutes then go and pull the knob out again and it will either hum or be working. I'm wondering if it could be the hidden lid switch.
sidfink43
#2 Posted : Monday, January 14, 2013 5:04:36 PM(UTC)
sidfink43
Normally the lid switch will be bad and just shut things off, but this does sound like a lid switch problem. Change it out and see if that fixes things. If not, the timing or the wiring to the motor or even the motor itself could be the problem.
Kenmore Washing Machine Model 417.29042992 (Washer Repair)
by jimylegg1 8/10/2020 5:39:45 PM(UTC)
Sears Kenmore Washing Machine 80 Series (Washer Repair)
by purecountry1127 11/4/2015 8:11:31 AM(UTC)
Kenmore washing machine not spinning without help (Washer Repair)
by narcsisuss 7/6/2015 5:54:17 AM(UTC)
Kenmore Washing Machine (Washer Repair)
by DStephens075@aol.com 6/19/2014 9:54:07 AM(UTC)
Kenmore washing machine, agitates while filling. (Washer Repair)
by Scott Eddy 6/2/2014 7:54:12 AM(UTC)
kenmore washing machine only fills (Washer Repair)
by stevieray2 6/7/2013 5:44:04 PM(UTC)
kenmore washing machine top load (Washer Repair)
by bigfig 6/19/2012 4:56:24 AM(UTC)
Series 90 Kenmore washing machine NO COLD WATER (Washer Repair)
by Char H 5/10/2012 8:29:36 PM(UTC)
kenmore washing machine wont start (Washer Repair)
by buddy93 2/8/2012 2:20:20 PM(UTC)
Kenmore washing Machine (Washer Repair)
by sstrueblue 12/18/2011 5:54:52 PM(UTC)
Kenmore Washing Machine Timer Shaft (Washer Repair)
by GLion 6/1/2011 8:27:48 PM(UTC)
My Kenmore Washing Machine (Washer Repair)
by ignefeus 5/23/2011 6:49:06 AM(UTC)
kenmore washing machine (Washer Repair)
by ron walburn 2/16/2011 8:14:57 AM(UTC)
kenmore washing machine series 70 (Washer Repair)
by raineywillow 9/22/2010 5:26:49 PM(UTC)
Kenmore Washing machine (Washer Repair)
by bjhamrick 5/25/2010 8:37:48 PM(UTC)
