bigfig
#1 Posted : Tuesday, June 19, 2012 4:56:24 AM(UTC)
bigfig
good morning my problem is my washing machine will not go past the rinse cycle it stops after agitating in the rinse cycle and does not drain and of course does not not go to the spin cycle. What can I do.
Simon / APP Team
#2 Posted : Tuesday, June 19, 2012 4:43:28 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you manually advance the timer to spin does it spin?
If it does - replace the timer Part number: 3951166
Good luck. Post the results.
Simon.
dave611
#3 Posted : Tuesday, June 19, 2012 4:59:15 PM(UTC)
dave611
I have the same issue, I have a kenmore 600 series sm 9711916 I can move the timer around and all i get is a humming sound. I can not get it to drain the water or rinse, but i can get it to work in the water filling phase
Simon / APP Team
#4 Posted : Tuesday, June 19, 2012 5:02:04 PM(UTC)
Simon / APP Team
Groups: APP Team
Provide the complete model number, please.
Simon.
dave611
#5 Posted : Wednesday, June 20, 2012 3:58:33 PM(UTC)
dave611
Simon.
Modle 110.27612600
type 111
ser CU3422918
Simon / APP Team
#6 Posted : Thursday, June 21, 2012 9:47:02 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Open the cabinet and check wire harness at the timer, motor and capacitor. Using the multimeter check the capacitor.
Remove the pump and try without it. There could be something jamming it.
Here is the capacitor Part number: 8572717
The pump Part number: 3363394
Use the video clip for the instructions.
Thank you. Post the results.
Simon.
