ron walburn
#1 Posted : Wednesday, February 16, 2011 8:14:57 AM(UTC)
ron walburn
Tub no longer spins,belt and pullies still in tact,but when the belt is rotated - the drum is not affected.
Joe / APP Team
#2 Posted : Thursday, February 17, 2011 8:55:09 AM(UTC)
Joe / APP Team
Ron,
Did you have a chance to check the wires and solenoids on the "wig wag" ?
Part number: AP3121800
You may also need to check the water level switch to make sure you have a closed circuit when the tub is empty.
If the wig wag solenoid doesn't activate, and shift the levers, don't engage, the unit won't spin,
Most of the time , the problem is due to a broken wire to the solenoid(s), that's where I'd start first.
Good Luck,
ron walburn
#3 Posted : Thursday, February 17, 2011 11:56:38 AM(UTC)
ron walburn
Joe - can you tell me, the solenoid you've mentioned, am I looking under the machine or behind the control panel?
Thanks,
Ron
Joe / APP Team
#4 Posted : Thursday, February 17, 2011 1:34:24 PM(UTC)
Joe / APP Team
Thanks,
Ron
Ron,
Your best bet and easiest access,
is to slide the washer out, to get in back of it and remove the rear access panel,
When you look inside in the gearcase/transmission area, it'll be mounted on a shaft on the top side of the gearcase, you can't miss it.
It'll have two wires(total of 4) going to each solenoid of the assembly, those are the wires and solenoids you need to check.
:cool: :cool: :cool:
ron walburn
#5 Posted : Thursday, February 17, 2011 1:53:17 PM(UTC)
ron walburn
Originally Posted by: Joe / APP Team Go to Quoted Post
Ron,
Thank you for your time!
Joe / APP Team
#6 Posted : Thursday, February 17, 2011 2:01:55 PM(UTC)
Joe / APP Team
Ron,
It's my pleasure to help,
Don't forget to let us know what you find, so we can post it to the forum, or move up to the water level switch, if we have to.
You can actually watch the solenoid(s), you'll see how the solenoid activates and engages the slide bar to shift from wash to spin, operation, from that vantage point, just don't reach inside, while it's operating.
Kenmore Washing Machine Model 417.29042992 (Washer Repair)
by jimylegg1 8/10/2020 5:39:45 PM(UTC)
Sears Kenmore Washing Machine 80 Series (Washer Repair)
by purecountry1127 11/4/2015 8:11:31 AM(UTC)
Kenmore washing machine not spinning without help (Washer Repair)
by narcsisuss 7/6/2015 5:54:17 AM(UTC)
Kenmore Washing Machine (Washer Repair)
by DStephens075@aol.com 6/19/2014 9:54:07 AM(UTC)
Kenmore washing machine, agitates while filling. (Washer Repair)
by Scott Eddy 6/2/2014 7:54:12 AM(UTC)
kenmore washing machine only fills (Washer Repair)
by stevieray2 6/7/2013 5:44:04 PM(UTC)
Kenmore washing machine (Washer Repair)
by MichelleM74 1/12/2013 11:51:42 AM(UTC)
kenmore washing machine top load (Washer Repair)
by bigfig 6/19/2012 4:56:24 AM(UTC)
Series 90 Kenmore washing machine NO COLD WATER (Washer Repair)
by Char H 5/10/2012 8:29:36 PM(UTC)
kenmore washing machine wont start (Washer Repair)
by buddy93 2/8/2012 2:20:20 PM(UTC)
Kenmore washing Machine (Washer Repair)
by sstrueblue 12/18/2011 5:54:52 PM(UTC)
Kenmore Washing Machine Timer Shaft (Washer Repair)
by GLion 6/1/2011 8:27:48 PM(UTC)
My Kenmore Washing Machine (Washer Repair)
by ignefeus 5/23/2011 6:49:06 AM(UTC)
kenmore washing machine series 70 (Washer Repair)
by raineywillow 9/22/2010 5:26:49 PM(UTC)
Kenmore Washing machine (Washer Repair)
by bjhamrick 5/25/2010 8:37:48 PM(UTC)
