bjhamrick
#1 Posted : Tuesday, May 25, 2010 8:37:48 PM(UTC)
bjhamrick
My washer went through the wash and rinse cycle but did not drain out the water. I used a garden hose to drain the water but it would not go though the spin cycle. My husband took the pump out and it seems OK and none of the tubes seem to be clogged.
sidfink43
#2 Posted : Sunday, May 30, 2010 6:13:07 AM(UTC)
sidfink43
By pass the lid switch and see if that makes things ok. It is the likely source of your problem.
bjhamrick
#3 Posted : Tuesday, June 1, 2010 6:39:10 AM(UTC)
bjhamrick
:) Thank you it was the lid switch it had pulled apart. Boo Hoo I already bought a new one.
sidfink43
#4 Posted : Tuesday, June 1, 2010 3:42:13 PM(UTC)
sidfink43
Ok, so fix the old one and sell it as a good used machine and get some of your money back!
Good luck with your new one.
Kenmore Washing Machine Model 417.29042992 (Washer Repair)
by jimylegg1 8/10/2020 5:39:45 PM(UTC)
Sears Kenmore Washing Machine 80 Series (Washer Repair)
by purecountry1127 11/4/2015 8:11:31 AM(UTC)
Kenmore washing machine not spinning without help (Washer Repair)
by narcsisuss 7/6/2015 5:54:17 AM(UTC)
Kenmore Washing Machine (Washer Repair)
by DStephens075@aol.com 6/19/2014 9:54:07 AM(UTC)
Kenmore washing machine, agitates while filling. (Washer Repair)
by Scott Eddy 6/2/2014 7:54:12 AM(UTC)
kenmore washing machine only fills (Washer Repair)
by stevieray2 6/7/2013 5:44:04 PM(UTC)
Kenmore washing machine (Washer Repair)
by MichelleM74 1/12/2013 11:51:42 AM(UTC)
kenmore washing machine top load (Washer Repair)
by bigfig 6/19/2012 4:56:24 AM(UTC)
Series 90 Kenmore washing machine NO COLD WATER (Washer Repair)
by Char H 5/10/2012 8:29:36 PM(UTC)
kenmore washing machine wont start (Washer Repair)
by buddy93 2/8/2012 2:20:20 PM(UTC)
Kenmore washing Machine (Washer Repair)
by sstrueblue 12/18/2011 5:54:52 PM(UTC)
Kenmore Washing Machine Timer Shaft (Washer Repair)
by GLion 6/1/2011 8:27:48 PM(UTC)
My Kenmore Washing Machine (Washer Repair)
by ignefeus 5/23/2011 6:49:06 AM(UTC)
kenmore washing machine (Washer Repair)
by ron walburn 2/16/2011 8:14:57 AM(UTC)
kenmore washing machine series 70 (Washer Repair)
by raineywillow 9/22/2010 5:26:49 PM(UTC)
