hello, i have a amana dryer thats less than 2 years old and yesterday when i put a load in the dryer then i pushed the start button its just buzzing as if its stuck on done signal:(
A model number may help others help you.
Is the buzzing from the end of cycle buzzer or the motor?
If it could be the motor. Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it. If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp. If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK. This may take 2 people Open the door Manually hold the door switch closed Push the start button and manually rotate the drum in the correct direction. Watch your knuckles in case it starts up. If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit. |
THIS FORUM IS DEAD!!!!!!! |
