Dhuggins
#1 Posted : Monday, June 11, 2012 6:22:07 AM(UTC)
Dhuggins
My Kitchenaid Superba
MOD# KAWS850LQ0
My washer will stop midway through a wash and make a loud buzzing sound and then quits all together.
If you let it sit for a while it will start up again and run fine.
Also, it leaks a little around the pump housing.
The leak is easy to fix, but I don't know where to start with the other issue. Maybe the leaky pump is causing the other problem?
Any help would be appreciated!
Simon / APP Team
#2 Posted : Monday, June 11, 2012 9:22:28 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the problem is bad timer Part number: 3955761
Here are the breakdown diagrams and Replacement parts for Whirlpool KAWS850LQ0 AUTOMATIC WASHER | AppliancePartsPros.com
You can always return any parts even if they been installed.
Thank you. Post the results.
Simon.
