lsanderson1
#1 Posted : Saturday, December 29, 2012 7:55:13 PM(UTC)
lsanderson1
hello, i have a amana dryer thats less than 2 years old and yesterday when i put a load in the dryer then i pushed the start button its just buzzing as if its stuck on done signal:(
#2 Posted : Tuesday, January 1, 2013 2:44:54 AM(UTC)
A model number may help others help you.
Is the buzzing from the end of cycle buzzer or the motor?
If it could be the motor.
Try turning the drum by hand. Should turn fairly easily. If not could be the drum is jammed for some reason. You may want to try this on a couple other dryers to get a feel for it.
If it is difficult to turn run your fingers around the back and front of the tub to machine seal. To see if something has jammed between the tub and frame (bra wires are famous for this). Be careful in case the object is something sharp.
If nothing is jammed in there you will have to open it up and find the cause.
If it rotates OK.
This may take 2 people
Open the door
Manually hold the door switch closed
Push the start button and manually rotate the drum in the correct direction.
Watch your knuckles in case it starts up.
If it does start up, odds are high that you need a new motor.
Could also be that the motor is jammed solid with lint and this is preventing the Start/Run centrifugal switch from resetting (the unit is trying to start with out the motor's start winding in circuit.
Kenmore Washer 110.92591220 Motor Buzzing Sound on Agitate (Washer Repair)
by IOO57 2/16/2019 12:30:15 AM(UTC)
Maytag Stackabl Dryer will not start, Makes the dryer Buzzing sound LSE7806ace (Dryer Repair)
by mdmitchell 6/29/2014 11:08:33 AM(UTC)
Dryer Makes end of Cycle buzzing sound when Start (Dryer Repair)
by CrossWashappliances 2/9/2014 12:16:15 PM(UTC)
Buzzing Sound From Transformer In Furnace (Heating, Ventilation, and Air Conditioning (HVAC))
by lacoppari 10/4/2013 2:45:29 AM(UTC)
Amana washer making a buzzing sound, does not wash, maybe bad transmission? (Washer Repair)
by SamyBoy 9/10/2012 6:36:19 PM(UTC)
loud dryer buzzing sound (Dryer Repair)
by man599 8/21/2012 6:22:49 PM(UTC)
Loud Buzzing Sound (Refrigerator & Freezer Repair)
by aty1ler 7/14/2012 9:27:51 PM(UTC)
Washer makes loud buzzing sound and stops (Washer Repair)
by Dhuggins 6/11/2012 6:22:07 AM(UTC)
glass cook top, no heat,buzzing sound (Oven Repair (including Ranges and Cooktops))
by george oro 6/7/2012 8:02:41 AM(UTC)
Amana Electric Dryer Buzzing Sound (Dryer Repair)
by amanabert 5/12/2012 11:48:31 AM(UTC)
Washer stopped during washing and made a buzzing sound. (Dishwasher Repair)
by Sherryla 5/8/2012 12:52:28 PM(UTC)
Dishwasher making loud buzzing sound before filling (Dishwasher Repair)
by ericdiy 4/19/2012 8:59:06 PM(UTC)
Buzzing sound, getting louder. (Dishwasher Repair)
by jerry201 4/2/2012 10:23:27 AM(UTC)
Microwave does not heat...buzzing sound (Microwave Repair)
by bnhmiles 3/15/2012 3:33:46 PM(UTC)
Buzzing sound (Refrigerator & Freezer Repair)
by RandyHunnie 3/5/2012 9:36:30 AM(UTC)
