icarus01
#1 Posted : Sunday, September 20, 2009 12:33:12 AM(UTC)
icarus01
After using this site to find a problem I had with my washer not draining I removed the mangled popsicle stick from the drain pump inlet and put everything back together to discover the washer would now drain but not agitate or spin. I hear the switches cycling but no agitation. I might add that I heard a popping sound when I was moving the washer back into place but I didn't smell anything. Any advice would be greatly appreciated...:confused:
Are there fuses...?
sidfink43
#2 Posted : Monday, September 21, 2009 6:06:15 AM(UTC)
sidfink43
Check to see that the belt is not broken.
If it is ok, a possible problem is the speed control board.
Here is the service manual which will show you how to do some troubleshooting. See page 50 in particular.
http://frigidaireservicetips.co..._TumbleActionWashers.pdf
icarus01
#3 Posted : Monday, September 21, 2009 8:52:18 AM(UTC)
icarus01
Thanks! I'll take your advice and let you know what I find!:)
Whirlpool Mod# LSQ9200KQ0 washer won't agitate or spin (Washer Repair)
by Guest 5/13/2023 11:34:56 AM(UTC)
Washer won't agitate or spin out. (Washer Repair)
by tracibailey 1/11/2019 8:43:20 AM(UTC)
Kitchen Aid Washer Won't agitate or spin (Washer Repair)
by M Yaworski 7/18/2017 7:00:37 AM(UTC)
Washer won't agitate or spin, and motor won't turn (Washer Repair)
by Jimmm59 8/24/2015 9:59:30 AM(UTC)
GE Profile Top Load Washer Won't Agitate or Spin (Washer Repair)
by keikomaru 3/21/2015 2:16:27 PM(UTC)
GE Washer Won't Agitate or Spin (Washer Repair)
by TXTerry 9/21/2014 10:35:00 AM(UTC)
GE Profile Washer Won't Agitate or Spin (Washer Repair)
by WisconsinMatt 8/19/2014 11:34:42 AM(UTC)
by patkat3 6/13/2014 8:04:56 AM(UTC)
Kenmore 90 series washer won't agitate or spin (Washer Repair)
by JayDigger 1/31/2014 9:30:29 AM(UTC)
Washer won't agitate or spin (Washer Repair)
by Jojam3000 12/17/2013 2:06:10 PM(UTC)
Frigidaire Washer Won't Agitate Or Spin (Washer Repair)
by paulem 10/7/2013 5:50:21 AM(UTC)
GE Washer Won't Agitate Or Spin (Washer Repair)
by Pat401 8/15/2013 3:01:45 PM(UTC)
by Stephenluck 6/12/2013 12:34:39 AM(UTC)
GE washer won't agitate or spin- no error codes (Washer Repair)
by Mark Falcon 5/13/2013 6:12:26 PM(UTC)
Washer won't agitate or spin, can turn motor by hand (Washer Repair)
by englaisfitz 11/14/2012 5:49:24 AM(UTC)
