After using this site to find a problem I had with my washer not draining I removed the mangled popsicle stick from the drain pump inlet and put everything back together to discover the washer would now drain but not agitate or spin. I hear the switches cycling but no agitation. I might add that I heard a popping sound when I was moving the washer back into place but I didn't smell anything. Any advice would be greatly appreciated...:confused:
Are there fuses...?
Originally Posted by: sidfink43 Thanks! I'll take your advice and let you know what I find!:)
