My dryer keeps turning off after 1-2 minutes and a faint rubber smell comes from the back. I already replaced the thermafuse but it still shuts off. What to do next?
I cannot get your model number to come up as a valid number.
If this is a gas dryer, check the posts on this Forum concerning gas dryers with your problem. The solution is most likely in replacing parts in the gas burner system. If the thermal fuses/thermostats are the problem the machine would not come on at all.
Good luck.
