dryer has excessive heating on all selections. it eventually stopped working. changed the thermal fuse and it started working again for about a week. it still has extreme heat on all settings. It again stopped working. Not sure what problem is.
Your problem is very likely a restricted venting system.
You need to take the dryer apart to get to the blower cover and take it off. Check to make sure the blower is operating correctly, and if so clean it out, and clean out the entire length of the vent from the inside of the dryer to the outside where the air exhausts.
That you do it.
