RAS
#1 Posted : Tuesday, May 26, 2009 2:32:23 PM(UTC)
RAS
I have an old Sears refrigerator in need of a defrost thermostat(bypassing the thermostat fires up the heating element) The OE thermostat is an L70. made by FSP(?) Do all L70 thermostats have the same heat specs? You carry this thermostat AP3108444 which appears to be the correct shape but does not have color coded wires. The OE has one white, one brown. Does this matter? thanks
applianceman
#2 Posted : Tuesday, May 26, 2009 2:54:40 PM(UTC)
applianceman
This doesn’t make any difference at all I actually use the same thermostat for nearly every refrigerator I work on. Refrigerator Not Cooling Repair Guide
RAS
#3 Posted : Tuesday, May 26, 2009 4:20:19 PM(UTC)
RAS
Interesting, they do come in all sorts of heat ranges. After my post, I realized that the OE is stamped 10-74 on the back. Those numbers jive with the open/close temp numbers in F with that new L70.
Melt the ice, don't set the fridge on fire, guess it's not rocket science. If the OE opens @74F, the worst that'll happen with a lower temp version is an incomplete defrost.
thanks.
applianceman
#4 Posted : Tuesday, May 26, 2009 4:42:01 PM(UTC)
applianceman
I am not saying you should do this but I have been putting the 60-degree GE thermostat on just about all refrigerators for years now. It is always best to order the right part but I know from experience that in most cases if that thermostat is 60-degrees the coils will are defrosted. There are certain refrigerators that I will not do this on I am just talking generally.
RAS
#5 Posted : Wednesday, May 27, 2009 3:28:24 AM(UTC)
RAS
Sounds good.
I had another old Sears fridge in the basement collecting dust and snagged the thermostat. That was before I realized the temp range was right there and so did not even look. It seems to be working OK. 60F seems a good compromise. They're cheap enough. I'll probably pick up a new one even though the "spare" is working.
thanks
Defrost Thermostat Stuck Closed? (Refrigerator & Freezer Repair)
by tim.widmann 6/3/2021 10:32:14 AM(UTC)
Want to give away a GE defrost thermostat (Refrigerator & Freezer Repair)
by Jorabi 6/27/2018 7:12:27 AM(UTC)
Defrost thermostat open/closed (Refrigerator & Freezer Repair)
by Jorabi 3/11/2018 5:25:55 PM(UTC)
refrigerator defrost thermostat (Refrigerator & Freezer Repair)
by joline 3/4/2017 2:15:53 PM(UTC)
Universal Defrost Thermostat (Refrigerator & Freezer Repair)
by rlogan 10/12/2016 1:06:39 PM(UTC)
Defrost thermostat rating (Refrigerator & Freezer Repair)
by RichNJ 9/3/2016 12:18:17 AM(UTC)
Replacing a 3 wire defrost thermostat (Refrigerator & Freezer Repair)
by arvetus 8/19/2016 6:53:56 PM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Replacing Defrost thermostat on (GE) Kenmore (Refrigerator & Freezer Repair)
by AUricle 7/14/2016 9:05:45 PM(UTC)
defrost thermostat not on Whirlpool diagram (Refrigerator & Freezer Repair)
by chrisyews 7/18/2015 6:22:00 AM(UTC)
Ice Build-up On Defrost Thermostat (Refrigerator & Freezer Repair)
by dantucson 7/31/2014 5:39:50 PM(UTC)
Defrost Thermostat DOA? (Refrigerator & Freezer Repair)
by spam 7/9/2014 3:27:06 PM(UTC)
How to test a defrost thermostat that has 4 wires (Refrigerator & Freezer Repair)
by appliance13 6/4/2014 3:20:27 PM(UTC)
Difference between defrost thermostats? (Refrigerator & Freezer Repair)
by Sockit 4/29/2014 8:10:13 AM(UTC)
Ice buildup on Defrost Thermostat (Refrigerator & Freezer Repair)
by russell@txwrights.com 1/20/2014 5:49:09 PM(UTC)
