Dryer will only heat up once a day
Will it heat up and run for a short time, or run till the load gets dry.
Originally Posted by: ThomasP Dryer will only heat up once a day You also might want to check and see if the gas comes on the first time it is turned on, and then when it cycles off, and the glow coil comes on the second time, and then no gas. You would need to replace the coils on the gas valve. Alot of times the coils on the gas valve get weak, and this condition occurs. Tom www.applianceeducator.com:cool:
