Dawna
#1 Posted : Friday, April 24, 2009 3:21:51 AM(UTC)
Dawna
My Washer won't Spin or drain at all. It fills fine and washes and thats all it will do now..:(
sidfink43
#2 Posted : Friday, April 24, 2009 12:36:02 PM(UTC)
sidfink43
Well, it sounds very much like your lid switch has failed, which if it has is a good thing because it is a cheap and easy repair.
To determine this you need to unplug themachine, remove the two screws holding your console to the cabinet (they may be behind trim pieces which can snap off) and then flip the console up and back.
This will expose a plastic electrical connector going into the cabinet. Disconnect this and use a jumper wire to connect the two outer terminals on the connector coming from the console. Then replug your machine, move the dial to the spin position and engage. If the machine spins the lid switch is your problem.
Any problems, search 'lid switch' on this forum and there are loads of discussions and instructions.
The part is
Replacement parts for WHIRLPOOL LSQ9544KQ0 | AppliancePartsPros.com
and you can search elsewhere on this forum for instructions of how to take the cabinet off and replace it.
Good luck and let us know what happens.
Dawna
#3 Posted : Friday, April 24, 2009 4:38:12 PM(UTC)
Dawna
Thank you so very much! You were so right.. My Lid switch snapped off the plastic part. So I actualy which was probably stupid on my part held it down manualy to drain the machine. I did go and purchase a new machine for the mear reason it is 9 years old and from what i was told they last anywheres from 10 to 12 years,, I appreciate this site so much.. I will be back.. Thank you again
sidfink43
#4 Posted : Friday, April 24, 2009 4:50:14 PM(UTC)
sidfink43
Thanks for the update, hope your new machine works well and that you don't have to come back!
Dawna
#5 Posted : Friday, April 24, 2009 5:52:45 PM(UTC)
Dawna
Thank you so much me either but I have added this site to my favorites and will tell my froends about it.. Have a great week end..
chisselgw2
#6 Posted : Saturday, November 21, 2009 7:28:03 AM(UTC)
chisselgw2
Ive Got Same Problem. Its Your Coupling On The Motor Where It
Connects To Gear Box. I Was Hoping To Find Out How To Install
It On This Site. No Luck Yet. Cant See To Good Anymore.
Good Luck With Yours. Chisselgw2
sidfink43
#7 Posted : Saturday, November 21, 2009 12:53:27 PM(UTC)
sidfink43
Washer won't drain or spin (Washer Repair)
by garywool93 3/19/2015 9:40:02 AM(UTC)
Whirlpool top load washer won't drain or spin. (Washer Repair)
by Owie55 3/6/2015 1:21:47 PM(UTC)
GE Front Load washer won't drain or spin (Washer Repair)
by rmgaris 2/8/2014 8:15:28 PM(UTC)
GE Washer won't drain or spin (Washer Repair)
by JenNC 1/30/2014 12:52:31 PM(UTC)
roper washer won't drain or spin (Washer Repair)
by Mr.Stormcrow 1/23/2014 10:03:40 PM(UTC)
Kenmore washer won't drain or spin (Washer Repair)
by jpaw24 11/11/2013 6:40:40 AM(UTC)
Kenmore 70 series washer won't drain or spin (Washer Repair)
by ImSR 10/12/2013 8:49:49 AM(UTC)
by Karen.Smith 3/18/2013 12:01:38 PM(UTC)
KitchenAid Washer won't drain or spin (Washer Repair)
by MSUMOM 3/14/2013 7:25:53 PM(UTC)
GE Front Loading Washer Won't Drain or Spin (Washer Repair)
by gblotter 2/8/2013 8:23:32 PM(UTC)
by smyrnaref 8/5/2012 11:06:04 AM(UTC)
whirlpool washer won't drain or spin, lid switch OK (Washer Repair)
by trip2012 6/18/2012 7:38:38 AM(UTC)
by helpplease911 4/3/2012 12:16:26 PM(UTC)
washer won't drain or spin in gentle mode (Washer Repair)
by Frub 5/8/2011 7:17:11 AM(UTC)
by bethandgil 4/12/2011 5:05:27 PM(UTC)
