maverickaf
#1 Posted : Tuesday, August 30, 2011 6:24:28 PM(UTC)
maverickaf
MDE6400AYW started having problems. Notice the timer dial was not moving all the time (just some times) when timer set. Started having issues with push/pull knob to start dryer. After reading some blogs, I decided to replace the timer unit (p/n 33002803) and now the dryer won't start. The light comes on when door is open. Any ideas????:(
maverickaf
#2 Posted : Tuesday, August 30, 2011 8:36:02 PM(UTC)
maverickaf
I found out my problem...wrong part. I found this out by looking at the pins (didn't have the same pins as the new part) where the plug goes into. The part I ordered AP4043083 should of been part number AP4042974. If you're going to switch out your timer, check your serial number for the right part. Serial numbers beginning with 10 should be part number AP4042974. :D
LG Dryer won't turn on, but light on inside drum. (Dryer Repair)
by pshoebri 4/22/2018 8:12:26 AM(UTC)
Help!! GE Dryer won't turn on unless you spin it (Dryer Repair)
by Ruben C 12/6/2014 4:46:28 PM(UTC)
dryer won't turn on (Dryer Repair)
by pansie 8/15/2014 3:21:29 PM(UTC)
dryer won't turn on until it has cooled (Dryer Repair)
by Cam2ron2502 6/7/2013 1:43:31 PM(UTC)
Dryer won't turn on the motor or heating element (Dryer Repair)
by axnst1 3/13/2013 6:03:28 PM(UTC)
Dryer won't turn on. (Dryer Repair)
by generic 7/24/2012 5:16:50 PM(UTC)
dryer won't turn on, also light stays on with door closed (Dryer Repair)
by mazw 7/24/2012 4:17:25 PM(UTC)
Maytag dryer won't turn on. nothing lit except light when open door (Dryer Repair)
by eprunty 6/22/2012 12:00:17 PM(UTC)
Roper dryer won't turn on need some help (Dryer Repair)
by Robdob363 2/2/2012 9:30:47 AM(UTC)
dryer won't turn on..code F01 displayed (Dryer Repair)
by leamarie 12/15/2011 5:56:44 AM(UTC)
Admiral Dryer won't turn on. (Dryer Repair)
by TheoT 11/22/2011 1:31:36 PM(UTC)
Dryer won't turn on (Dryer Repair)
by Lisa M 8/4/2011 6:34:07 AM(UTC)
by daveh59 7/4/2011 4:43:58 PM(UTC)
by momvilla 6/2/2011 2:14:44 PM(UTC)
by idgie 1/24/2011 5:37:22 AM(UTC)
