aaagood
#1 Posted : Saturday, February 21, 2009 10:15:37 AM(UTC)
aaagood
the motor some times works emty and not when clothes are place in the bin , and some times works with the cloths in the bin , some times is not working at all . All the time when is not working I hear the noice like the motor is turning but the bin in not turnig. What is the proplem?
thank you
aaagood
#2 Posted : Saturday, February 21, 2009 10:20:04 AM(UTC)
aaagood
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
#3 Posted : Saturday, February 21, 2009 12:18:54 PM(UTC)
MDE9606AYW
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16023086.pdf
Try moving the drum by hand, it should rotate fairly easily.
The humming you hear is either
1. the motor running and the belt is slipping so the drum does not turn
2. the motor cannot start and it hums usually this requires that the motor be replaced. Normally if left like this it will overheat and trip it's internal thermal cutoff.
So you may be lucky and it may be just a slipping belt.
Check the belt and the idler.
Might as well also check rear rollers, front glides etc.
Also a good idea to give the interior a good clean and clean/check the vent system.
jlaass
#4 Posted : Tuesday, May 5, 2009 7:16:37 PM(UTC)
jlaass
deleted, see below
jlaass
#5 Posted : Tuesday, May 5, 2009 7:20:42 PM(UTC)
jlaass
I located this post and subsequently the service manual for my dryer, which helped me figure out how to put the belt on and complete the repair. I thought I was losing my mind with the other photos of how the belt fits on most Maytags. Thanks!
Jeff
Originally Posted by: denman Go to Quoted Post
MDE9606AYW
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
