svalencia58
#1 Posted : Sunday, March 20, 2011 3:07:17 PM(UTC)
svalencia58
roper dryer mod: REX3614JWO hard to start and turn, stops working after a couple of minutes, won't start again until it cools off, than stops working.
svalencia58
#2 Posted : Sunday, March 20, 2011 3:14:04 PM(UTC)
svalencia58
Originally Posted by: svalencia58 Go to Quoted Post
roper dryer mod: REX3614JWO hard to start and turn, stops working after a couple of minutes, won't start again until it cools off, than stops working again, it heats normal the couple of minutes that it works.
#3 Posted : Monday, March 21, 2011 6:39:47 AM(UTC)
Replacement parts for WHIRLPOOL REX3614JW0 | AppliancePartsPros.com
Sounds like your motor is overheating, tripping it's internal thermal protect and then you have to wait for the motor to cool down before re-starting.
Often this is caused by the motor being on it's last legs.
Try turning the drum by hand in the correct direction. It should turn fairly easily. You may want to do this on a couple other units to get a feel for it. This checks if there is a drum mounting problem that is overloading the dryer.
Check that he seal between the blower and the motor is OK so that hot air is not blowing back onto the motor.
Also check/clean your vent system so there is no back pressure.
You could also check the voltage (L1 to Neutral) should be 120 volts.
Low voltage will cause the motor to overheat but usually it would not start. This is a very rare fault.
If all OK then replace the motor.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
