dirkster1313
#1 Posted : Friday, December 26, 2008 12:58:00 PM(UTC)
dirkster1313
Dryer runs for a few seconds then stops. It starts to slow down then stops. It then makes a humming sounds and sounds as if something is preventing the drum from turning. If shut off right away then it will restart without waiting. Problem then repeats. If I wait to shut it off then it takes a few minutes to reset itself before starting.
I took apart the front and inspectd all the wheels and belt. Everything works find but at times it seems as the drum is sticking.
Drags1998
#2 Posted : Friday, December 26, 2008 2:31:27 PM(UTC)
Drags1998
I'll be willing to bet that the MOTOR is bad, Take the belt off, put it on AIR FLUFF and start it, If the thing quits in the same amount of time, Its the motor!!!!
dirkster1313
#3 Posted : Friday, December 26, 2008 6:17:19 PM(UTC)
dirkster1313
When put on air dry the motor works fine for a long period of time. It
#4 Posted : Saturday, December 27, 2008 2:54:52 AM(UTC)
You might have a shorted centrifical switch on the side of the motor,check it for burnt pins.
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
