my dryer is making alot of noise i can move my tub up and down about a 1/2 inch to a inch.could this be bearings? and how hard will it be to fix myself? it dries really well . any help would be great.. thanks:
On your dryer, you have a ball and socket support for the drum. Remove drum by pulling up on the back and check the socket, probably worn real bad. If so, this site will need your model # to order it.
