just replaced the thremal fuse and it blew again why
2 things to look for. 1. The ventilation, Is there a large amount of lint build up in your dryer? 2. Check continuity between the heater element and ground if the heater is shorted it will continue to heat without the blower running and this would cause a thermal fuse to open.
