jbandbb1
#1 Posted : Sunday, February 6, 2011 10:34:04 AM(UTC)
jbandbb1
our dryer just quit. you can turn it on and the control lights all light up. when you press start, it clicks and nothing happens. the clicking noise is in the top panel. Any ideas?
#2 Posted : Monday, February 7, 2011 2:54:35 AM(UTC)
Replacement parts for WHIRLPOOL WED6400SW1 29`` ELECTRIC DRYER | AppliancePartsPros.com
Here is a manual
Whirlpool 8178584 Cabrio Dryer Service Manual - ApplianceDigest.com
You will have to join the site to get the manual.
I am assuming that the interior light works and everything else looks normal.
If yes then I would check:
1. Belt switch - could be just a broken belt.
2. The thermal fuse - if it is blown clean/check your vent system as this is the most common cause of it blowing.
Note: The parts breakdown does not show a thermal fuse while the manual does (Page 5-2). I do not know which is correct.
Samsung Dryer eats up drum rollers (Dryer Repair)
by boyd0384 1/6/2019 10:09:21 PM(UTC)
Need to sweep timer switch to start dryer (Dryer Repair)
by jebstep 1/4/2019 8:17:56 PM(UTC)
Maytag Dryer blinking lights won't start (Dryer Repair)
by LRP116 12/15/2018 6:25:54 AM(UTC)
GE Adora Dryer Moisture Sensor Replacement (Dryer Repair)
by RedCoat999 12/14/2018 1:38:37 PM(UTC)
Bosch Nexxt Premium Gas dryer (Dryer Repair)
by logcabin1 12/5/2018 4:31:40 PM(UTC)
Electrolux dryer - long dry times (Dryer Repair)
by twinlabs 12/5/2018 7:58:01 AM(UTC)
dryer blower wheel replacement (Dryer Repair)
by lancehenley1 12/4/2018 11:42:59 AM(UTC)
Low heat on Whirlpool thin twin electric dryer (Dryer Repair)
by lotusTT 12/2/2018 4:06:08 PM(UTC)
GE Dryer replaced control board and all the lights are flashing (Dryer Repair)
by cjfordvt 12/1/2018 6:17:07 PM(UTC)
Dryer heats up but takes too long to dry (Dryer Repair)
by bear0729 11/13/2018 6:35:10 AM(UTC)
Electrolux Washer Dryer Combo (Dishwasher Repair)
by dhowe 11/10/2018 1:55:37 PM(UTC)
Dryer Model WED5000DW2 Need help on dryer door handle (Dryer Repair)
by tljohnsonrealtor@aol.com 11/1/2018 9:44:58 AM(UTC)
Dryer still not heating after new parts were installed (Dryer Repair)
by rclion0410 11/1/2018 8:48:03 AM(UTC)
Maytag Dryer Panel Lights Work But Won't Start (Dryer Repair)
by G-Daddy 10/31/2018 4:37:11 PM(UTC)
Frigidaire Gas Dryer Shuts Off After Less Than A Minute Run Time (Dryer Repair)
by hooter726 10/23/2018 11:54:54 AM(UTC)
