need to replace baffle how do i get to the screw does top open
Originally Posted by: jordon ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) need to replace baffle how do i get to the screw does top open Real easy. You need to take the door off. There is one screw that holds the top of the hinge to the cabinet, and one on the bottom hinge. Then lift up on the door, and pull it out. Now on the other side of the front, as if there was a left hand door remove those two screw, and the front will come off, you can get to it from there. If you need more room, take the 2 screws off that hold the top down. Tom ApplianceEducator.com
