jesramos
#1 Posted : Friday, November 5, 2010 3:02:28 PM(UTC)
jesramos
i recieved and installed new defrost thermostat. the fridge seems to be cooling in both compartments. my question is... the coils are building up frost around them. is this normal? does the defrost ther. work on a continues basis or how does it work.
Joe / APP Team
#2 Posted : Friday, November 5, 2010 3:48:03 PM(UTC)
Joe / APP Team
Jess,
In most cases the defrost thermostat is a closed circuit below a certain temperature(usually some where in the 35 degree range).
When the refrigerator is in a cooling mode, it is normal to have an even coat of frost on all the coils of the evaporator.
After a certain amount of accumulated compressor run time(usually 8 hours).
The defrost timer or ADC control board cycles the defrost cycle on, and with the thermostat closed the heater comes on and stays on until the defrost thermostat opens and turns the heater off.
There's usually a 10 to 15 minute delay, after the heater turns off, before the control turns the power back on to the compressor and the cooling cycle begins, again.
Hope this was helpful,
:cool: :cool: :cool:
Defrost Thermostat Stuck Closed? (Refrigerator & Freezer Repair)
by tim.widmann 6/3/2021 10:32:14 AM(UTC)
Want to give away a GE defrost thermostat (Refrigerator & Freezer Repair)
by Jorabi 6/27/2018 7:12:27 AM(UTC)
Defrost thermostat open/closed (Refrigerator & Freezer Repair)
by Jorabi 3/11/2018 5:25:55 PM(UTC)
refrigerator defrost thermostat (Refrigerator & Freezer Repair)
by joline 3/4/2017 2:15:53 PM(UTC)
Universal Defrost Thermostat (Refrigerator & Freezer Repair)
by rlogan 10/12/2016 1:06:39 PM(UTC)
Defrost thermostat rating (Refrigerator & Freezer Repair)
by RichNJ 9/3/2016 12:18:17 AM(UTC)
Replacing a 3 wire defrost thermostat (Refrigerator & Freezer Repair)
by arvetus 8/19/2016 6:53:56 PM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Replacing Defrost thermostat on (GE) Kenmore (Refrigerator & Freezer Repair)
by AUricle 7/14/2016 9:05:45 PM(UTC)
defrost thermostat not on Whirlpool diagram (Refrigerator & Freezer Repair)
by chrisyews 7/18/2015 6:22:00 AM(UTC)
Ice Build-up On Defrost Thermostat (Refrigerator & Freezer Repair)
by dantucson 7/31/2014 5:39:50 PM(UTC)
Defrost Thermostat DOA? (Refrigerator & Freezer Repair)
by spam 7/9/2014 3:27:06 PM(UTC)
How to test a defrost thermostat that has 4 wires (Refrigerator & Freezer Repair)
by appliance13 6/4/2014 3:20:27 PM(UTC)
Difference between defrost thermostats? (Refrigerator & Freezer Repair)
by Sockit 4/29/2014 8:10:13 AM(UTC)
Ice buildup on Defrost Thermostat (Refrigerator & Freezer Repair)
by russell@txwrights.com 1/20/2014 5:49:09 PM(UTC)
