Groups ready for retrieval: Registered
dryer was drying and in the middle of drying stop drying and when i went to turn it back on it would not turn on at all
It is probably the thermal fuse on the back. Without a model number I can't tell you which part you may need. Also turn your breaker off then back on and see if that helps. Nat
