calebjnewcomb
#1 Posted : Tuesday, June 9, 2009 7:06:46 PM(UTC)
calebjnewcomb
Dryer will run a few minutes but kicks the breaker I replaced the cord but did not fix the problem any help out there?:eek:
#2 Posted : Wednesday, June 10, 2009 2:58:16 AM(UTC)
Could be the heating element is heating up, sagging, touching the case and blowing the breaker. Remove the heater and check for tell tale scorch marks.
Could be that the breaker is toast. Only true way to tell is with a clamp on ammeter so you can monitor the current going to the machine.
calebjnewcomb
#3 Posted : Thursday, June 11, 2009 3:33:08 AM(UTC)
calebjnewcomb
Heating element seemed to be OK, no burnt Marks or unusual coloring and the breaker checked out OK. Did I mention before that when the dryer runs the breaker heats up almost to hot to touch. Any more thoughts on the matter if so I am up for suggestions.
#4 Posted : Thursday, June 11, 2009 11:57:58 AM(UTC)
Sounds like a bad connection at the breaker
Amana Dryer (ned4655ew1) vent glows when door is open (Dryer Repair)
by Guest 7/2/2024 9:31:47 AM(UTC)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Dryer timer replacement help (Dryer Repair)
by Guest 6/20/2024 8:14:36 AM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Maytag Atlantis gas dryer model MDG7400AWW (Dryer Repair)
by Guest 6/13/2024 10:59:46 AM(UTC)
GFQ14 - Combination Washer / Condenser Dryer GFQ14ESSN0WW (Dryer Repair)
by SoakingWet 6/13/2024 10:48:53 AM(UTC)
Samsung DV328AGW Dryer heats for 10 seconds then shuts flame off (Dryer Repair)
by attim0de 6/13/2024 8:07:31 AM(UTC)
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
Speed Queen gas dryer Model SDG809WF (Dryer Repair)
by Guest 6/3/2024 11:05:10 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
MGD6000BWW Maytag gas dryer (Dryer Repair)
by Guest 5/17/2024 11:37:29 AM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
