arodriguez01
#1 Posted : Tuesday, February 6, 2018 8:29:06 AM(UTC)
arodriguez01
I Have A Maytag Centennial Washer Model Mvwc360awo. When It Is Time To Spin The Clothes The Basket Does Not Spin, But The Aggitator At The Bottom Does , Causing The Wet Clothes To Ball Up To One Side. I Know This Because I Took The Lid Off And Duck Taped The Top Lid Switch To The Bottom So I Can Watch What Is Happening While It Washes. Also When The Basket Does Move By The Clothes Rubbing It When The Aggitator Balls Up The Clothes Or By Moving It By Hand It Makes A Loud Skweaky Noise But Moves Freely Both Ways. Thanks For Any And All Help
brobriffin
#2 Posted : Thursday, February 8, 2018 3:13:38 PM(UTC)
brobriffin
Man
United States
I suspect you need to replace the actuator (shifter).
Confirm by running a diagnostic test and looking at the error codes.
The tech data sheet which will guide you through the diag sequence is located inside the front panel in a ziplock bag.
arodriguez01
#3 Posted : Saturday, February 10, 2018 2:33:36 PM(UTC)
arodriguez01
thanks, i will do this tomorrow on my day off
brobriffin
#4 Posted : Monday, February 12, 2018 9:03:08 AM(UTC)
brobriffin
Man
United States
Good let us know the results
Guest
#5 Posted : Friday, June 4, 2021 4:22:28 PM(UTC)
Guest
Rank: Guest
Groups: Guests
United States
Here is a Youtube video on how to go about fixing a Maytag Centennial washing machine:
Maytag centennial washer- motor won’t spin (Washer Repair)
by Guest 3/30/2024 1:59:24 PM(UTC)
Maytag Centennial Washer MVWC415EW0 Agitation issue (Washer Repair)
by Guest 5/27/2021 9:58:45 PM(UTC)
maytag centennial washer low fill (Washer Repair)
by redjada 9/3/2017 9:01:47 AM(UTC)
Maytag Centennial Washer doesn't Agitate (Washer Repair)
by hosehead78 4/16/2017 5:46:30 PM(UTC)
Maytag Centennial Washer Stops Mid-Cycle (Washer Repair)
by washer2017 3/16/2017 5:58:01 AM(UTC)
Maytag centennial washer drum sits too low (Washer Repair)
by jansmeall 12/8/2016 11:59:20 AM(UTC)
maytag centennial washer wont goo into spin cycle (Washer Repair)
by shennondw 8/9/2016 6:20:41 PM(UTC)
Maytag Centennial Washer (Washer Repair)
by fivermillions 2/21/2016 5:23:23 AM(UTC)
Maytag Centennial washer stops after filling (Washer Repair)
by dfrancey 5/5/2015 7:41:28 AM(UTC)
Maytag Centennial washer will not start (Washer Repair)
by TurnpikeJ09 3/8/2015 7:44:44 PM(UTC)
by maytagQuestion 3/2/2015 1:11:52 PM(UTC)
maytag centennial washer (Washer Repair)
by Scotty1231 10/5/2014 7:45:25 AM(UTC)
Maytag Centennial Washer Transmission??? (Washer Repair)
by Fixit-teer 4/13/2014 6:58:06 PM(UTC)
by ShadeTree231 3/23/2014 5:02:51 PM(UTC)
maytag centennial washer, loud spinning sounds (Washer Repair)
by korean1 11/16/2013 6:53:18 PM(UTC)
