lizardking508
#1 Posted : Sunday, June 21, 2015 12:00:22 PM(UTC)
lizardking508
My GE washer will not agitate. It will fill up with water, do nothing in the agitate cycle, drain, spin, then turn off. It does everything but agitate. When it is in the agitate cycle the motor and belt will spin(in one constant direction, but the agitator don't move. I replaced the motor a few years ago, and the replacement came with a relay and capacitor setup instead of the clutch assembly. Can you please point me in the right direction.
Thanks,
Ron C.
fairbank56
#2 Posted : Sunday, June 21, 2015 3:18:14 PM(UTC)
fairbank56
Groups: Expert
Can you easily rotate the lower agitator by hand? If so, the agitator coupler is probably stripped out. Pull the agitator, remove the coupler and check for stripped splines up inside the coupler. If you can't easily rotate the lower agitator, then you have a bad transmission.
Eric
lizardking508
#3 Posted : Sunday, June 21, 2015 5:27:53 PM(UTC)
lizardking508
thanks Eric.
the coupler is stripped.
Ron
Kenmore Washer will not agitate, but it will spin (Washer Repair)
by mjaymadson 8/2/2022 9:37:22 PM(UTC)
Estate washer will not agitate properly (Washer Repair)
by Guest 4/21/2022 8:19:49 AM(UTC)
GE washer will not agitate or spin (Dryer Repair)
by grim509 5/10/2018 8:11:57 PM(UTC)
kenmore washer will not agitate (Washer Repair)
by crawdadcreek 7/29/2015 10:07:27 AM(UTC)
GE Washer will not Agitate or Spin at times. (Washer Repair)
by jackchis 4/6/2015 4:33:00 PM(UTC)
Ge Washer Will Not Agitate Or Spin (Washer Repair)
by Lmaynard99 2/26/2015 8:51:44 PM(UTC)
Washer will not agitate (Washer Repair)
by jemiller33 11/25/2014 4:02:02 PM(UTC)
Washer will not agitate, or spin (Washer Repair)
by win809doo 5/19/2014 8:19:45 AM(UTC)
Washer will not agitate, spin, or drain (Washer Repair)
by nosinina 4/16/2014 8:42:37 AM(UTC)
Washer will not agitate, but does spin. (Washer Repair)
by Kas23 3/18/2014 2:50:05 PM(UTC)
washer will not agitate or spin (Washer Repair)
by CHERIE KING 2/27/2014 8:16:38 AM(UTC)
by dan mayville 12/23/2013 1:52:45 PM(UTC)
GE washer will not agitate but will rinse and spin (Washer Repair)
by gabemich 11/20/2013 8:35:25 AM(UTC)
Washer will not agitate spin or drain (Washer Repair)
by mdbk 11/6/2013 7:49:14 PM(UTC)
washer will not agitate but will spin out clothes (Washer Repair)
by wolf234 9/23/2013 11:08:26 AM(UTC)
