The washer will not agitate, or spin. But will fill and pump water out. I have replace the lid switch, but the problem is still there. Is it the in line fuse? If so where is it at? Thanks in advance.
I don't think it is the line fuse. This model has a diagnostic built into the motor electronics, a flashing light. Here is a link on how to interpret error codes. HydroWave GE Washer Repair GuideSee if that helps. Good luck.
