win809doo
#1 Posted : Monday, May 19, 2014 8:19:45 AM(UTC)
win809doo
The washer will not agitate, or spin. But will fill and pump water out. I have replace the lid switch, but the problem is still there. Is it the in line fuse? If so where is it at? Thanks in advance.
sidfink43
#2 Posted : Tuesday, May 20, 2014 6:02:59 PM(UTC)
sidfink43
I don't think it is the line fuse. This model has a diagnostic built into the motor electronics, a flashing light. Here is a link on how to interpret error codes.
HydroWave GE Washer Repair Guide
See if that helps. Good luck.
