Washer fills normally and agitates but then does not drain or spin. Bailed out the water from the tub - still would not spin. Tried different settings on the timer (i.e. permanent press/gentle/etc.) - does not pump the water out or spin. I'm guessing not motor related as fill/agitate work. Is this the timer failing? Any insights would be helpful. Thanks. This is my son's washer, a poor college student, so we would like to try to repair ourselves if possible!
Groups: Expert
Thank you for the quick response. we purchased the lid switch and installed it and the washer is working again. My son and I appreciate the forum.
