Originally Posted by: fairbank56 Yes, it's only a 2-pin connector. Jump the two pins together. That's the wiring harness receptacle, not the connector on the end of the lid switch :) Believe me, people have done that before.
Eric I'm in the process of ordering the switch right now!! I will get some wire tomorrow from my shop( auto mechanic, don't know why I didn't think of the bypass method once I didn't get continuity on switch ):) thank you a million Eric!!! My wife thinks I'm a genius now :D
Groups: Expert
Check my last post, I added to it. You can use existing switch connector to make jumper.
Eric
Originally Posted by: fairbank56 Check my last post, I added to it. You can use existing switch connector to make jumper. Eric Splicing as we speak :) you are the man I'll let u know how it goes
So I spliced the wires and it worked like a charm!! The switch will be here on Friday. I wish I could buy you a drink or coffee or something :) you saved me so much grief. Thank you so much!
Groups: Expert
No problem, glad to be able to help out. Keep that machine going, you don't want to have to buy any of the junk washers they are selling nowadays.
Eric
Tell me about it. All she wants is a front loader and I keep telling her that according to the reviews they aren't worth it
Originally Posted by: fairbank56 No problem, glad to be able to help out. Keep that machine going, you don't want to have to buy any of the junk washers they are selling nowadays. Eric Eric please help!!! So the washer was working fine for a couple days after bypassing the lid switch and this morning it stopped agitating and spinning again :( ... The lid switch arrived today and I replaced and still nothing.. I did notice that even with the power off I can hear some ticking from timer I believe. What else can I try?
Groups: Expert
Originally Posted by: fairbank56 I guess that's what I'll be ordering next.. It's just wired that all of a sudden the timer just goes but oh well you haven't steered me wrong yet. Thanx
Another few questions. Do you know which wires are the hot and ground for the motor? And is there an easy way to test the motor since I have the panel off already? That timer is over a hundred bucks. Do you think it's worth fixing? Thanx in advance
